Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4490 Questions View all
Front and rear camera, flashlight not working , help...
Hello everybody. This is my first question on this site, so please try to help me.
I have changed iphone 6 housing with new one, the MB was working 100% before the replacement, and now i have gut a problem with the rear and front camera and flash light they don't work!!!!
I have checked everything on MB, Camera's, flex cables, components,
I tried all kind of restores, even new framwear. It doesn't help
And also i put the MB on another 100% orginal and working phone, still the same ,
I am working with iPhones almost 3 years and i am professional but this is my first case whene I couldn't find a solution,
Does anyone know the solution of my problem????
Score 1
Add a comment
The storage isn't full is it? I know on the iPhone the camera will not work if the device has no space. I've seen in some cases where it will not tell you the storage is full when you go to the camera. Pretty lame but it might be worth a shot! As for the flashlight it might be a board issue if you have tried multiple flex cables.
Comments:
Hello Leevancleef, thank you for your answer .
My first setup was to do a factory reset so i had completely empty memory but it doesn't work.
I'm sure that i have hardware problem. Why ?? No idea yet
by
I totally missed that I am sorry! I know on the 6 some water cleanups we have had the camera never comes back on. t could be a component that was damaged (if not by liquid something else) Are you able to test with a different camera?
by
I am facing same problem. Actually my phone was !#^&@@ off by car. But everything is working fine except both cameras & flashlight. Is it MB problem or camera's problem? There is no crashes around front camera but housing around rear camera is totally messed. Is there any common components between rear cam, front cam & flashlight? Should I try on MB or cameras? Or if cameras then which camera I should replace?
by
I had to replace both my front and rear cameras recently (my phone was also run over), and when the rear (main) camera was bad, the flashlight wasn't working. When I replaced it with a new camera, the flash and flashlight worked. So they're connected.
by
Add a comment
Here is guide for you. Hope it can help you:
How To Fix iPhone 6 Camera Not Work After Repairing
Comments:
That link seems to be broken.
by
Add a comment
Add your answer
Armen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 1,123
