A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
814 Questions View all
Why the game won't show on t.v.?
The PS4 come on but it don't show on t.v.
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
There are several things that could be happening here. You could have a bad HDMI cable but the most likely cause is that you have a bad HDMI port. This is a very common problem with PS4's. The HDMI port that Sony installed has lots of weak points and they go bad easily.
You'll likely need an HDMI port repair.
I hope this helps.
Score 1
Add a comment
You will need to find a tv or monitor it works on then change the video settings to be compatible with the tv you would like to use, For example 480p,720p,1080p
Good Luck
Add a comment
Add your answer
Lydia will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 39
