Keyboard Replacement and repair
I attempted to replace the keyboard on my Acer Aspire 5253-BZ684, seems like an easy task, when I was removing the old keyboard ribbon from the connection, I broke the connection. Can that be repaired?
Score
0
A picture of the connection and how it is broken might be helpful as well. Replacing a connection on the motherboard is very hard to replace, soldering on parts that small is not easy without causing more damage, assuming you could find a new connector. I have had keyboard connectors where just the pressure tab popped out, and those can sometimes be popped back into place(picture will help here). If the plastic part attached to the board is broken that will make it very hard to repair.
by crunchy005
