Bose Soundlink Bluetooth Mobile Speaker II was originally released in September 2012 as an upgrade from the original device. It has an effective range of 30 feet and a battery life of up to 8 hours.
19 Questions View all
Question Closed
The speaker isn't playing any music.
The speaker shows the two devices are connected, but there isn't music playing.
Add a comment
1 Answer
Chosen Solution
Hi,
Check to see that the mute button is not activated, that the volume on the speaker is up. Also check that your music source is playing.
If still not working try pairing another device and see if it works.
If still no good clear the memory by holding the Bluetooth button for about 10 seconds (a tone will sound), then try re-pairing your device.
As a check to see if your speaker is working connect an audio source, using a 3.5mm stereo audio cable to the Aux input. Press the AUX button and check that the AUX source indicator is on. If there is no sound your speaker is faulty.
Here is a link to the user manual.
http://worldwide.bose.com/productsupport...
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,868
