Also known as Sony Xperia Z1 Honami, Sony Xperia Z1 C6902/L39h, Sony Xperia Z1 C6903, Sony Xperia Z1 C6906, Sony Xperia Z1 C6943. Released September, 2013.
56 Questions View all
Is possibol to change battery z1?
how to change batterry sony z1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Hi,
Here is a link which shows how to disassemble a Sony Z1.
To swap the NFC from the old battery to the new battery :
Note: take notice of the alignment of the NFC on the old battery before you remove it from the battery.
The NFC is attached to the battery with adhesive. Just very carefully pull it off from the old battery and make it stick to the new battery with some 3M adhesive sticker. Be careful and make sure of its alignment.
https://www.youtube.com/watch?v=LAutRUkp...
Score 3
Add a comment
You could watch this sony xperia z1 teardown video to get some repair tips: https://youtu.be/SvJKVxfKqFc?list=PLM3XY... . To replace the battery, you need to remove the back cover and the back frame firstly.
Add a comment
Add your answer
masoud will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 43
All Time: 1,667
