Repair guides for the MacBook Air, Apple's current line of consumer laptops.
4815 Questions View all
Screen goes black/inverted/garbage, fixed after sleep
I have a "late 2010" MacBook Air 13" (C2D 1.86GHz, the version without the backlit keyboard). It has not been spilled on, suffered any trauma, etc. Was working fine (sitting on a stand, plugged into a 20" Dell monitor) and today all of a sudden the laptop screen (but not the Dell) went sort of inverted, with some garbage.
Since then, I've been using the laptop by itself, and it's done it a couple of times since then. Every time the effect is a little different; the most recent one, the screen went solid black with some red pixels. Usually it looks more or less like this:
Picture showing the screen malfunction
If I put the computer to sleep (either by power key then 's' key, or by closing the lid, waiting until the backlight illuminating the Apple logo switches off), the problem is fixed immediately after the computer resumes from sleep (open the lid or hit a key on the keyboard).
I don't think it's a loose cable, since the problem is fixed without moving anything but simply sleeping and waking the computer. Thoughts? (The motherboard was replaced by Apple a couple of years ago, it was losing all settings and going back to 1970 every time the battery ran out while the computer was sleeping. But no problems in 3+ years of fairly constant use...)
Score 1
Add a comment
Have you tried an SMC and/or PRAM reset? That's what Apple recommends you do if your computer is acting strangely.
Here's how to do the resets...
If that doesn't help, the problem is at least narrowed down to:
  • OSX software bug (some system file corruption for sleeping?)
  • LCD malfunction
  • Logic board malfunction (on GPU)
This is assuming that any video output externally is working perfectly fine.
Reformatting and reinstalling your OSX wouldn't hurt, but it might take you the whole evening to wait for it to install. Be sure to create a Time Machine backup to an external drive with enough space, that way you can restore to exactly where you left off with all of your data intact.
Hope this helps...
Add a comment
IT should be your motherboard malfunction as apple stuff is not normarlly meant to be open but you can try to reformat
Score -2
1 Comment:
I'm not sure what this means... Especially "apple stuff is not normarlly [sic] meant to be open." Also, why would reformatting change anything? The screen is normal on external displays. It's just the internal screen that's affected. That doesn't suggest software in any way.
by
Add a comment
Add your answer
rch will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 305
