Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Battery drain after screen replacement.
Hi All,
I got a cracked screen on my iPhone 6, the first replacement that i got didn't work at all, but when i reconnected the original again, it worked again.
So I returned the screen and got a replacement. Now I installed this one, it works fine, also all other functions of the phone work, accept for the touch ID and the battery drains by the minute..... Any suggestions?
---Update---
Apparently the battery drains only when the screen is in use, if i dont use the phone the battery usage seems normal...........
Bad screen assembly again?
I disconnected the screen and checked all connectors with a magnifying glass and they look ok to me, no shorts or damage. I also left the home button flex disconnected since i damaged the flex, but it still drains the battery when the screen is in use.....
Score 1
Add a comment
1 Answer
I'm wondering why your Touch ID didn't work anymore?
1 Comment:
I tought i was very carefull removing the LCD shield with the homre button flex, apparently I was not carefull enough..... :(First i tought i made a short by damaging the flex, but after disconnecting it (the whole flex from the mainboard) result is the same
by
Add a comment
Add your answer
KoenP will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 919
