2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Key on the keyboard is stuck (the key between delete and enter/return)
Basically i spilled some water on the keyboard and the trackpad. I let it dry out, took it to the genbar and they replaced the trackpad. except now one of the keys (the key between delete and enter/return) will randomly get stuck and type until i press the delete button. what can i do?
Score -1
2 Comments
Is the key physically stuck or does it just remain in the pressed state although being up?
by
it remains in the pressed state although being up. so basically when i turn on my mb, randomly the key will start pressing the \ button until i press delete.
by
Add a comment
1 Answer
Chosen Solution
The keyboard consists of several layers. The "active" one (with all the switches and leads in) is most likely affected. Unfortunately this is almost impossible to fix. You might need a new topcase/keyboard)
1 Comment:
how much would it cost to do something like this? also, do you think the spill could have damaged anything else according to how deep the water has gone down?
by
Add a comment
Add your answer
Zenas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,171
