The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
729 Questions View all
iPad 2 black screen
My iPad 2 screen went black... i see it's turn on... back light but no image. Hard reset won't do nothing. When i do a screen capture i momentarly see my screen a little...
I tried to to hit it a little like i saw in some messages but it's doing nothing. Any help please?
Score 3
Add a comment
Chosen Solution
Yeah, your backlights out. Not super big on iPads. But, I think you just need to replace the LCD.
iPad 2 Wi-Fi EMC 2415 Front Panel Replacement
iPad 2 LCD
iPad 2 LCD Image
Product
iPad 2 LCD
$59.99
Score 2
Add a comment
It's likely that the iPad will need to have the lcd cable reconnected. Sometimes smacking the back doesn't work. With the proper instructions And patience you can open the iPad and do this. Be sure to power the iPad off first though. Just hold the power button for about 5-10 seconds then swipe not the screen towards the top where slide to turn off would be. You should see the backlight dim slightly then turn off.
Follow the ifixit guide to open an iPad 2, and you'll be good to go.
Score 2
Add a comment
Didn't work, followed the procedure and did what was required with no changes. Still a dark screen.
Add a comment
Add your answer
martinesabourin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 801
