Released by Ematic in 2012 the tablet has a 9.7 inch screen.
3 Questions View all
Why won't my device charge?
I have to hold the charging cable in order for my device to charge.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
If you're device is not charging after trying to charge it on multiple functional outlets, it is possible you have a bad battery, or it may be that a wire is lose inside your device. Open your device carefully and look on the circuit board for the word BAT in small print, with a negative and positive wire connected to it. If the wires are connected to the circuit board, check the charging port (where you would connect the charger to the tablet) which should be on the edge of the circuit board and see if there is anything lose or missing. If everything looks fine it is likely you will have to replace the battery of your device.
Add a comment
Add your answer
Cassandra Ralph will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 77
