White screen With Apple logo
My MacBook air is some Times starting with black screen and sometimes With white screen and Apple logo but nothing happens after that.
Anyone knows how to repair?
1.Try a Safe Boot
Mac OS X 10.2 and later Safe Boot includes disk checking and repair. First start your Mac in Safe Mode. To do this, shut down your Mac. Now Turn on your computer by pressing the power key while holding down the Shift key. When you see the Apple logo, release the Shift key. After your Mac fully starts, restart your computer normally without holding any keys/buttons during startup. Note that Safe Boot is slower to boot.
2.Run Disk Utility
Turn your Mac off by holding down the power button for a few seconds. Turn on your Mac and hold down the Command and R keys until you see the Apple logo. Then you should see a “Mac OS X Utilities” window. Select Disk Utility, click your OS X hard drive and select verify/repair disk.
3.Reset PRAM
This may fix your boot failure. PRAM (“parameter random-access memory”) stores some of your settings. You may reset PRAM. To do that, turn off your Mac. Now turn on your Mac. Then, immediately, hold down the Option-Command-P-R keys until your Mac restarts. When your Mac is starting up, release the keys.
4.Reinstall Mac OS X
If nothing above works, you may try this. Your Mac needs to be connected to the Internet. See number#2 above. Follow the same steps. Restart your Mac and hold down the Command key and the R key until the Apple icon appears; when you see the Mac OS X utilities window, select the Reinstall option.
ariyawansanuwan, good answer just make sure that you give credit to the site where you copied this from. http://appletoolbox.com/2014/09/mac-fix-...
oldturkey03 always thanks for the advice noted
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 132
I mean i can not log in
by Ala
Tried safe mod and got only Apple logo
Tried rundisk and got only Apple logo
Tried reset pram and got a white screen only
Cmd+r is not taking me to osx utilities
by Ala
