Repair and disassembly guides and support for dish washing appliances.
705 Questions View all
Maytag dishwasher MDB-3 fills, runs a few seconds, then stops.
This unit fills properly, then runs maybe 3 seconds, then stops.
After opening, unit has water in tub (it should).
Hitting start/cancel causes unit to drain properly.
After opening, unit is dry (it should be).
Can find no obvious blockages.
Motor works, pump works, etc. The machines is 13 yrs. old but runs very well. Don't want a new one. Thanks you!
Score 2
Add a comment
1 Answer
Most Helpful Answer
Door Lock Motor and Switch Assembly
The door lock secures the washer door shut during operation. Once the washer door is closed, the washer can begin operating. If the washer door is not latched shut, the door switch will prevent the washer from operating. If the door lock is defective, the washer will not spin or start. The door lock can fail either mechanically or electrically. Inspect the door lock for damage. If the door lock is damaged or does not latch properly, replace it. To determine if the door lock has failed electrically, consult your washer’s wiring diagram and use a multimeter to test each of the door lock switches for continuity. If one of the switches does not have continuity, replace the switch.
Score 1
1 Comment:
Door lock is okay. Washer runs maybe 10 seconds then stops.
by
Add a comment
Add your answer
gdmagnin2 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 3,533
