The Jeep Cherokee (XJ) is a compact SUV that was manufactured and marketed by Jeep from 1997 to 2001. Sharing the name of the original full-size SJ model, but without a traditional body-on-frame chassis, the XJ instead featured a light-weight unibody design.
38 Questions View all
high oil pressure malfunction?
hello,
i am facing high oil pressure. i disconnected switch the gauge oil pressure come down when i connect switch coming high.
Comments:
So it's your gauge or do you have high oil pressure? Changed the oil filter? What else have you tried?
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
I have solved it. Oil switch sensor was loose and I tight it. Now it is working in good condition.
Add a comment
Add your answer
Ghanim ALAdawi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 87
