Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1952 Questions View all
How can I restore the backlight after rain damage?
my wife left the phone out in a rainstorm for 3 hours. she put in a bag of rice for a few days and the phone appears to work great with the exception of the backlight makes it almost impossible to see. you can still activate all aps on the screen you just cannot see the screen very well. how can we fix this problem?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Hi Charles,
We'll there are a few ideas circulating how to fix the back light problem, in my personal experience i found that cleaning the contacts with alcohol fixed the problem on a few peoples phones i've fixed.
Follow this guide up to and including step 6: iPhone 3GS Display Replacement
You should now have 2 half's of an iPhone.
Where you unseated connectors 1 2 and 3, clean the connectors on the logic board and the connectors coming off the screen part (both parts of the connection) with alcohol, isopropyl.
What usually happens is that the "breaker" has dropped / left their phone in liquids that when dried out leave a residue or a build up of a certain other substance that doesn't conduct so the connection is broken on a few pins where the substance resides.
In your case there is probably mildew or some other rain impurity left in your phone.
Hope this helps.
James.
Add a comment
If you have access to another 3G S then you could remove it's entire upper assembly and replace your phone's display with it and see if the issue lies with your LCD connector or if it's actually the connector or another issue on the motherboard.
Add a comment
Add your answer
CHARLES FULLER will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,713
