The Panasonic Lumix DMC-TS20 Camera is a waterproof, shockproof, and freeze-proof digital device used to take pictures or videos. It’s good to use in active activities.
5 Questions View all
Why won't the battery charge?
Whenever I plug the charger into the battery, it won't charge.
Add a comment
1 Answer
Chosen Solution
There are a couple reason why the battery for the camera won't charge. One reason is that the charger itself may not work. If you have an extra battery or another device that uses the same charger, try using the charger with those. If the charger charges the other battery or the other device, that means the battery for your camera is bad and needs to be replaced. If the charger didn't work on the new battery or the other device, then that means the charger is broken and needs to be replaced with one that has the same serial number/ specifications.
Add a comment
Add your answer
Toby Alves will be eternally grateful.
Past 24 Hours: 12
Past 7 Days: 56
Past 30 Days: 204
All Time: 2,705
