Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
Question Closed
iPhone restart over and over every 5 seconds
my iphone restarts over and over every five seconds and i cant put it on recovery mode or dfu for restore it. then when i finally could put it on dfu,i plug it to itunes and start to restore it but whe the iphone will make its first reboot starts rebooting again and again every 5 seconds
heres a video taken from the iphone https://www.youtube.com/watch?v=NKtdJyaX...
pd: hope you can under stand my cuestion
Add a comment
Most Helpful Answer
Sounds like a battery issue, i would reseat the battery connector from inside the phone.
Score 1
1 Comment:
I already disconnect the battery and re connect it you think i need to replace it?
and when i start to restore i have 89%
by
Add a comment
You can try the following step:
As the phone begin to reboot, press and continue to hold the + volume button. This process starts the iPhone in "Safe Mode." It may allow you to return to the Lock screen. Perhaps this will assist you in restoring the device in iTunes. I would love to hear how this turned out for you.
Thank you,
Michael
Update (01/04/2016)
Try the following:
1. Disable iCloud syncing
When stuck in iPhone blue screen of death in iwork, one workaround to alleviate the iWork-related reboots is to disable iCloud syncing for Apple's Pages, Keynote, and Number apps.
2. Use the freeware ReiBoot
There is an excellent program called ReiBoot. It is the freeware and you can use it to restart your iPhone in blue screen of death. It will never cause any data loss or damage to your iPhone.
Download and install ReiBoot on your Windows PC (Windows 10/8.1/8/7/XP/Vista). Mac users go to ReiBoot for Mac and it works on Mac OS X 10.11 El Capitan, 10.10 Yosemite, 10.9/10.8/10.7/10.6.
Score 1
1 Comment:
no work :( ,I tri it but whatever I do the iPhone stills rebooting until I press home + power for 30 seconds he power off.
the full story it's tis: when te 9.1 be releases I try to upgrade (OTA) but don work something gone wrong an I fall in to a boot loop so I put the phone in recovery mode and I start to restore it then in the first reboot start the problem. the iPhone starts a rebooting again and again every 5 seconds and now finally I pit it on dfu mode but it's te same story in iTunes says waiting for the iPhone and the iPhone starto to looping again
before that happens when I have ios 8.2.1 some times the iPhone bricks and turns completely blue screen (similar at the windows blue dead screen without the white text ) eventually shut down himself and when the ios starts I unlock it and after 5 minutes the iPhone reboots himself again and I could solve that problem restoring and upgrading to ios 9.0.2
hope you could understand my English, this is not my mother language
REALLY THANK YOU GUYS 4 T HELP
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,382
