Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
273 Questions View all
Can I replace the CD Drive on the white iMac?
I recently purchase a 2006 White Imac for $25.00, the Imac is beautiful and still working pretty good, but was wondering if there was a way to give it a little speed upgrade using an SSD; I am also interested of installing a second drive where the current Cd drive is located...is it possible? Anyone done such upgrade?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Your problem is backward compatibility to SATA I 1.5GHz per second.
I would go with a 3.5" hybrid drive. This one will work for you:
Seagate 1.0TB Desktop SSHD Solid State Hybrid Drive
ST1000DX001
This drive should be large enough so that you have no need to change out the optical drive.
1 TB SSD Hybrid 3.5" Hard Drive
1 TB SSD Hybrid 3.5" Hard Drive Image
Product
$109.99
Score 1
Add a comment
Add your answer
chrisimo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 45
