A Windows 8 laptop series by Acer with Intel Core i3 or i5 CPU.
63 Questions View all
Laptop won't turn on or charge.
So my laptop was on about 10% and so i plug the charger when i plugged the charger the laptop turned off itself and wont even charge. it was perfectly working last night and i dont know whats the problem..someone help me what to do?
Model: Acer Aspire V5-431
Score 4
Add a comment
If you have another charger lying around try it. Sounds like the charger may have malfuntioned.
Add a comment
Hi. Disconnect the charger. Now take out the battery and plug the charger back in. See if the laptop will now boot from the charger. If it does, then you need to buy a new battery. Don't run the laptop for too long from just the charger as it can damage the charger.
Comments:
My laptop won't turn on but it's still charging. What should I do?
Model: Aspire V5-132P
by
my laptop stil doesnt boot from my charger.
I even tried other working chargers.
by
I had this same issue so I took out the battery and plugged the charge in and it work. I then turned my computer back off, unplugged it and put the batter back on. Once the battery was back on I plugged the charger back in and my computer works fine. Does that till mean I need a new battery?
by
Add a comment
Maybe the motherboard got short circuit.
Comments:
why would plugging in the charger short circuit the motherboard??
I ask because exactly the same thing happened to me, and no amount of suggestions and nothing I did made it turn on again. I gave up and sadly it remains gone. But was the issue with the charger? or a faulty circuit? or something else???
by
Add a comment
Add your answer
Tashia Holland will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 55
All Time: 4,754
