Random stop without error code. C00 through C08 works perfect.
Regardless of the wash setting, the machine stops filling, will flash for 30 seconds, and then resume ... repeatedly. I ran the 'testing cycle' (C00-C08) several times and all steps are being completed as expected except C005 but my machine is not a HE3T so I didn't expect it to. It did not spin during C005
I've changed the computer, the flow meter, and the pressure valve (names may not be perfect). Ran good for a week, and now problems again. Blew into the hose for the pressure valve and was free of obstructions. Drain not clogged and also put in a new drain pump.
Tried running a blank load to eliminate overloading possibility but still has problems
Starting at 45 mins, it will run until 43 sometimes, 35 sometimes, and 11 sometimes. Sometimes will run for 3 seconds and kick off, sometimes several minutes.
I've checked the door switch for continuity and that is fine.
Any help is greatly appreciated.
