Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
3614 Questions View all
Why is my speaker not working
Please help me. After changing the backcover the speaker stopped working.
I replaced the it with a new one but it didn't work. The exchange of the audio jack flex cable unit didn't help me either.
What did i miss? What can i do to solve this probem? Really everything works fine but the speaker..
Score 1
Comments:
Did you check the hardware mute switch status ?
by
Yes of course.. But i dont think that it's a problem with the mute switch because normally music can be listened to while the mute switch is 'on'...
by
Then you have to replace audio codec
by
how can i replace it? It's soldered to the mainboard, isn't it? And where can i order the audio codec/another mainboard? the only link i've found is around 450 USD and thats way too much. Anyway, replacing the mainboard won't work or am i wrong?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Sometimes the grill for the aftermarket backs are not good i suggest just poke the 6 holes with a needle on the bottom right you should get some sound.
Comments:
unfortunately it didn't help...
by
Before you do any board repair try replacing the speakers and charging port first again
by
Add a comment
Add your answer
Chenzin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 289
