What does code E1 mean
What does code E1 mean and how do you fix it.
joe gillan, E1 is a Thermistor error. First of course disconnect the power. Then remove the lint filter screen. Remove the two screws from the bottom flange of the toe kick panel. Pull the toe kick panel out at the bottom, pull down, and remove the panel. Remove the screw from the lint duct bracket and remove the bracket. Remove the two screws from the lint duct and remove the duct. You'll find the white thermal fuse on your blower wheel housing, right beside it is the thermistor. Replacing it should eliminate E1. The Whirlpool part number is 8577274 and in the attached image the part is located at position 42
Decent video about that particular repair can be found on here
E1 means: Thermistor Failure. You will need to replace this.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,415
