Why is my iPhone not turning on?
I dropped my iphone in a cup of coffee and now it wont turn on it just shows a picture of the apple sign.I want to know what it is that needs to be fixed.
you'll need to follow the guide to disassemble your phone to get the motherboard out. then carefully (very carefully!) take the silver metal cover off the motherboard-(I've used a small flat head screwdriver but others may have better ideas, to lift each little metal tab up on the metal cover so it lifts...there's lots) then use a soft brush and isopropyl alcohol to clean all the white and green residue from all the parts and connectors. clean all the other parts as best you can. leave it to dry then reconnect to usb.
see what happens, either it's good to go or a part has shorted out with the water and you'll need to solve that problem....
you could also just try a restore if the phone is recognised in itunes?
my iphone went extremely dead this morning, i am now trying to charge it and it is not coming on. what can be the problem?????????? please help
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 594
