Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2687 Questions View all
How to repair after water damage
So after my phone spent over a week in the lake I put it in a bag of rice for a few days which left me with a phone that wouldn't even turn on. I started dissembling the phone to replace the battery, but I can't seem to find the new iPhone 6s battery to replace it with. What else should I do to fix my components or test them to rebuild my phone? also any suggestions on where to find a new battery?
Score 1
Add a comment
1 Answer
Most Helpful Answer
noahschmidt, whoa. Two things are already going against you. First the rice, always skip the rice. It will not prevent corrosion nor will it fix the phone, it is a misleading myth. It is the equivalent of not doing anything. Second the waiting for a few days. Bad idea since corrosion will start immediately. It would have been safer staying in the water.
STOP continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.
The very first step I would take is to disassemble your phone. Use this teardown to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You absolutely must remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. Yes it is still pretty difficult to find a battery, but that is secondary. If you wait any longer before you properly clean the phone, you won't need a battery. Hope this helps, good luck.
iPhone Image
Guide
Repairing iPhone Liquid Damage
Difficulty:
Difficult
1 - 2 hours
iPhone 6s Image
Guide
iPhone 6s Teardown
Difficulty:
Moderate
Score 3
Add a comment
Add your answer
noahschmidt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 5,011
