The HP All-in-One desktop personal computer released in the Summer of 2013. This 20" touchscreen is an ideal family home computer that can function as both a desktop and a mobile computer.
5 Questions View all
My headphones don't work when I plug it into the jack?
My headphones work fine when I'm using them on my phone but for some reason they don't work when I plug it into my computer. How do I fix this?
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Alyssa Kristedja. Make sure that the drivers for your audio card are properly installed. Also, and I know this sounds stupid, but make sure that your headphones are properly plugged in to the headphone jack, not the mic etc. If that still won't work, check the bios to make sure that your audio card is properly initialized.
Score 2
Add a comment
Assuming your headphones do in fact work, it might be that the device isn't recognizing them or just overrides them. If this is the case then you can manually connect and set your headphones as default through these steps..
For Windows 8 and 10 move your mouse to the top right of your screen and then straight down to bring up the charms sidebar.
a. Click settings
b. Click Control Panel.
c. Go to Hardware and Sound.
d. Click on Sound.
e. Right click your headphones in the pop-up window
f. Click connect
Hopefully this will set your headphones as the primary playback device. If this fails see the troubleshooting page mentioned above.
Score 2
Comments:
What if you dont see your headphones in that window???
by
i dont see the word connect as on option, so i just clicked ok but it still didn't work.
by
Add a comment
i need help y headphones wont work and i cant use them and they are brand new
Comments:
i have tried to have mine fixed but they still wont work even by a prefessinal. does anyone know how to fix this?
by
what if your setting don't have a control panel
by
Add a comment
Add your answer
Alyssa Kristedja will be eternally grateful.
Past 24 Hours: 54
Past 7 Days: 472
Past 30 Days: 2,298
All Time: 27,637
