7.9 inch display iPad Mini, with 16, 32, or 64 GB of storage.
662 Questions View all
Apple iPad Mini: What do I do now?
My ipad was disabled by my little brother and it says to connect to itunes. I have an hp laptop so i cant exactly get to itunes on this. How do i get my ipad enabled again. :(
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
You can download iTunes from the Apple website on your HP laptop, without any problems ;)
http://www.apple.com/lae/itunes/download...
It is from the official Apple website so no virusses or malware.
Succes!
Score 1
Add a comment
1- Connect the device to the computer you normally use for synchronization.
2- Open iTunes. If iTunes asks you to enter your code, try another computer you have performed synchronization. Or try to use recovery mode using the following steps.
3- iTunes automatically synchronizes your device and create a backup. If the process does not start automatically synchronizes the device with iTunes.
4- Once synchronization is complete, restore the device.
5- When the iOS Configuration Wizard asks you to configure the device, select "Restore from iTunes backup."
6 - Select your device in iTunes and select the most recent backup copy.
and thats it!!!!
Score 1
Add a comment
Add your answer
Taejsha Ramoon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 52
