A television game console produced by Sony Computer Entertainment, first announced February 20, 2013 and released November 15, 2013.
605 Questions View all
Why is my console so loud?
My ps4 has been overheating/making a loud fan noise for the past 3 months or so and I've yet to find the reason. I've changed the thermal paste for my ps4 yet it didn't fix the problem and hardly made a difference. Please help
Comments:
Does the light turn red then make 3 beeps and shut down?
by
No, not at all
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Based on your answer to my question your console isn't actually overheating. If it was overheating it would beep 3 times, turn on the red light and shut itself down.
As far as why the fan is running high, there are several things that might be causing that...it could be that it's plugged with dust (this does not sound likely since you said you opened it up...I'm assuming you cleaned it while you had it opened). It could also be that you are playing larger games that take up more memory and have intense graphics...this can make the console run hotter and therefore turn the fan on higher.
Unless it's causing some other problem I wouldn't worry about the higher fan speed.
Interestingly Sonys newest model of PS4 the CUH-1200 runs quieter than any of the previous 2 versions.
I hope this helps.
Score 1
Add a comment
Most Helpful Answer
Is it just the sound of the fan running on full speed or there are additional rattling noises?
Score 1
Comments:
Both, i get a occasional rattaling noise here and there but that was after i changed the thermal paste which is strange
by
Add a comment
Add your answer
Gairo Zamora will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 462
