Many people have answered the question correctly but not explained properly
Firstly make sure the battery of the Docking Station and Laptop are fully charged
THIS IS A MULTIPLE STEP PROCESS
Put on Bluetooth on your laptop by going to Settings and Devices
All the steps to do this are explained here as far the buttons are concerned
https://www.asus.com/gr/support/FAQ/1011...
Basic Set Up - Step 1 to Step 3 in the link above
Follow as in the Link
Now you go to Step 4
Click on Pair
You will have either the option of automatically getting a password in numbers from the laptop - Shown in link Step 5
or
You will get the option of choosing your own password in numbers - Shown in link Step 6
Remember you will either reach Step 5 or Step 6 (Not Both - Please don't ask me why)
1) Now if you reached Step 5 and whatever number you get (example here is 63467904)
Enter that in the Docking Station Carefully Correctly and Slowly - Press Enter
You will not be able to read what you type on the Docking Station (example here is 63467904). That is why do it correctly and right.
It will automatically take you to Step 7 and connect your Docking Station
2) Now if you reached Step 6 instead of Step 5 then you have to choose the number (example let us choose here 12345678)
I chose 8 digits because I noticed Asus had automatically generated an 8 digit code
Then enter 12345678 on the tablet keypad of your computer in the white box and click Next
You will see the signal showing "connecting"
Now go to your Docking Station and enter 12345678 in the Docking Station Carefully Correctly and Slowly - Press Enter
You will not be able to read what you type on the Docking Station (example here now is 12345678). That is why do it correctly and right.
PLEASE REMEMBER FOR EITHER 1) OR 2) THE DOCKING STATION PAIRING BLUE LIGHT MUST BE FLASHING AND THE LAPTOP MUST BE IN PAIRING MODE. IF BLUE LIGHT STOPS FLASHING IT WILL NOT GET PAIRED
To check if your Docking Station works well I used this trick (in case you have doubts on its functioning)
a) Switch off your Tablet
b) Make sure Docking Station is fully charged
c) Go to your mobile phone
d) Put both the Docking Station and Mobile Phone on Bluetooth Scan Mode
e) If you find the Docking Station try to connect it. It will give you a pairing number (example here is 63467904 - not always this number)
This means your Docking Station is perfect
(Absolutely a stupid way with no proper explanation by Asus. I wasted 3 hours figuring it out. I am no Geek. I did this all by trial and error. Nothing is wrong with your Bluetooth device on the docking station under most circumstances. Just to help others who got stuck and frustrated like me)
Hi,
Is the info here relevant to your problem
https://www.asus.com/us/support/FAQ/1005... especially about the bios update
by jayeff
The problem that I have mine is that it’s not the keyboard connector. It’s the one on the tablet. So I was going to pair it with a blue tooth keyboard and case. But that brings to mind another problem. What case will fit the best
by earnieroberts
