Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
LCD Display cable nr 1 & 3
Hey Guys,
what is the best way to FIX those LCD Cables 1 & 3,Number 3 doesn't hold when i push the white plastic tap down & Number 1 always is loose or really hard to connect again.
Any Ideas???
Thanks in Advanced
Score -1
Add a comment
1 Answer
Chosen Solution
try putting a bit of tape across connector 3, it will stay in if you're really careful on closing. as to connector 1 try putting a small screwdriver or your finger on from the side until you have nearly closed front display. you could also try a very thin piece of foam on top of connector to apply extra pressure when closed.(it has to be quite thin or display will not close at all)
also check you have purchased the correct generation parts as they aren't interchangeable
Score 2
Add a comment
Add your answer
Kevin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,357
