Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Questions View all
iMac 21" Power Button issue
How do I change the power button of my iMac 21" My iMac has a power button problem. I have to keep pressing it until it starts.
I think it is an issue with the Button from the first day. It's a 2010-2011 model.
Does Apple have an out of warranty solution for this? Personally, I think the power button should be replaced. How to do this?
Score 1
1 Comment
Hi There
I had same problem, but a little heat to the back around the Power Button will loosen the glue which will allow you to remove the power button assembly for easy soldering.
by
Add a comment
1 Answer
Chosen Solution
You may have a logic board or power supply problem. The power switch is a soft switch design. It uses a low voltage logic to then fire off a relay on the power supply which then turns on the computer.
If you are able to use a multimeter you could take a measure of the switch to see if its working and you can also check the rest of the circuit. Follow this IFIXIT guide: iMac Intel 21.5" EMC 2428 Logic Board Replacement. Jump down to Step 22 and locate the Purple marked connectors. The lower one is the power switch.
Score 2
Add a comment
Add your answer
docinix will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 6,134
