Format a Samsung 2TB HD - ST2000LMI003 HN-M201RAD for optical bay use
I am trying to format the 2TB ST2000LM003 HN-M201RAD for use in the optical bay of my MBP 17" Early.
I have formatted it several times and used restore from a Thunderbolt external dock and it works fine.
As soon as I place it in the optical bay via the OWC Data Doubler, MBP wants to initialize the disk. It show as a master boot and not GUID. I have tried to Partition it with the Disk Utility Mac OS Extended (Journaled) option GUID. It just hangs with the words "Waiting for disk to reappear".
Is this a problem the OWC Data Doubler? Or will a 2TB drive not work in the optical bay?
5 Comments
Please give us the last four figures of the serial number of the Mac you are using, there are lots & lots of MBP Early 17" machines with different BUS speeds. A link to the OWC doubler you are using wouldn't hurt either.
by mayer
Sure
DRJG
Intel 6 Series Chipset:
Vendor: Intel
Product: 6 Series Chipset
Link Speed: 6 Gigabit
Negotiated Link Speed: 6 Gigabit
Physical Interconnect: SATA
Description: AHCI Version 1.30 Supported
ST2000LM003 HN-M201RAD:
Capacity: 2 TB (2,000,398,934,016 bytes)
Model: ST2000LM003 HN-M201RAD
Revision: 2BE10001
Serial Number: S377J9AG901992
Native Command Queuing: Yes
Queue Depth: 32
Removable Media: No
Detachable Drive: No
BSD Name: disk1
Rotational Rate: 5400
Medium Type: Rotational
Partition Map Type: MBR (Master Boot Record)
S.M.A.R.T. status: Verified
Volumes:
disk1s1:
Capacity: 2 TB (2,000,398,933,504 bytes)
BSD Name: disk1s1
Content: 0xEE
by CBR
OWCDDAMBS0GB,
OWC Data Doubler Optical Bay Hard Drive/SSD Mounting Solution for all Apple MacBook & MacBook Pro 'Unibody' Models; all MacBook Models 'Late 2008' and Later. Replace your optical drive with a Hard Drive or SSD!
by CBR
MacBook Pro 17" 2.2 GHz i7 (Early 2011)
by Dan
You have a Samsung Spinpoint drive not a Seagate drive. Seagate bought Samsung's hard drive division a few years ago so you often see people confuse the different drives.
by Dan
