The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
248 Questions View all
Question Closed
Replaced Screen and Digitizer - Now Home and Back Button Don't Work
I just replaced the screen and digitizer on my Note 3. This is my first time doing anything like this. The screen works and is responsive for the most part; the home and the back button are not working. The turn-on button on the side works when I press it really hard. Did I not put it back together properly? Why isn't the home and the back button working?
Add a comment
1 Answer
Most Helpful Answer
Hello!
Iyou need to check to see if the flex is wrong connected, because the best is what could happen, if not that, then the screen came damaged.
Luck!!
Score 1
2 Comments:
How do I know if the flex cord is connected properly?
by
look at the cells of the connector and check you are well and you can do it also with a multimeter measuring watts!
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 94
