Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3188 Questions View all
Which flex cables are connecting the logic board with the case?
Which flex cables are the ones coming from the logic board and tightened with two screws to the case?
Here in step 22: iPhone 5 Lightning Connector and Headphone Jack Replacement
Was sind das für Flexbandkabel/Anschlüsse die von der Hauptplatine abgehen und mit den beiden Schrauben am Gehäuse verbnden sind?
Siehe Schritt 22: iPhone 5 Lightning Anschluss/ Kopfhörerbuchse ersetzen
I believe what your asking about is the flex cables for the power button, but I'm confused, because it's a guide for the Lightning dock
Add a comment
Chosen Solution
Those two are GPS and cellular diversity antenna connectors, if you tore them you have to desolder the GPS front end module and install a new one.
Score 2
Add a comment
They are not flex cables, they're attached to the logic board and screw in at the top of the housing. Probably there for grounding.
Score -1
No, they are antennas.
Add a comment
Add your answer
sebastianeschholz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 56
