Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
542 Questions View all
Sparked Motherboard and Smoke?
My iMac recently made a loud pop noise and about 2 minutes later it smelled like smoke but was not coming out! I don't know if it was a spark in the motherboard or not, and if yes I am scarred because I had a lot of stuff on that computer. My grapics card had to get replaced but I haven't yet. And it has been about 3 months since I have turned it on and I wanted to transfer data to external hard drive but now I think I can't. Please Help!
Add a comment
1 Answer
Chosen Solution
This sounds like a blown capacitor, diode, or other similar component. There is a strong possibility that your hard drive is still working. Disassemble the computer using one of the many guides on this website and remove your hard drive . Put the hard drive in an external dock (you can buy them online for ~$20) and attach it to another computer to extract the data. Alternatively you can find the circuit board with the damaged component by looking for burn spots surrounding a missing or damaged component. Once you locate the damaged circuit board you can try replacing it. Keep in mind that if part of the power supply is damaged then it probably took the other components with it like the motherboard, processor, and even hard drive. Because of this possibility I highly recommend checking to see if the hard drive is working before you attempt a full system repair.
Score 1
Comments:
Thank you!!!
by
Add a comment
Add your answer
Elias S will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 385
