Missing resistor around headphone jack
Been given a destroyed 5s to fix, it was basically mashed up from a ride on lawnmower!!!
So the bottom left had the microphone cut off, and also the little resistor flex that goes around the headphone jack.
What is this part actually called, as I'm having problems locating it, and what's its function?
Amazingly, everything else is working fine!!!!
Many thanks
Update (10/21/2015)
Just to be clear. I am replacing the whole dock connector.
BUT the small part in the link below is damaged, it is this part which does not come with the new dock connector.
This is attach with a small amount of adhesive and secured with the two screws at the bottom left and top right of the headphone jack.
This would normally be taken off the original, but this one is torn from the breakage.
1 Comment
Duane, add a few images of your damage etc. with your question to avoid confusion. Use this guide Adding images to an existing question for that. Also, mark the component that you think you are missing.
by oldturkey03
