Swap hard drive in different MacBook Pro models?
Hello,
does anyone know if it’s possible to swap a hard drive from a Macbook Pro 15" Unibody (late 2009) model and put it into a Macbook Pro 13" Unibody (early 2010) in order to boot from it and secure data? The normal hard drive would go back into the 13" after the procedure. Or will there be problems because OSX would have been installed on a different model?
Long story short: Macbook 15" took a beer bath, won’t start, the hard drive was not damaged and it was unfortunately 2 weeks since the last backup. I’d like to get at the data that accumulated in those two weeks.
Thanks in advance for any answers!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Yep should work fine they are both 2.5in Sata Drives. Plug and play
Score 3
Add a comment
How about using this: SATA Optical Drive USB Cable it will allow you to hook up your HD externally to your other Mac.
SATA Optical Drive USB Cable Image
Score 1
Add a comment
Add your answer
oldschoolashell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 68
