The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Questions View all
My Ipad fell on the floor, won't charge or turn on
My IPad 2 slipped out of it's case and fell on the floor. It won't charge or turn on. I would like to get it fixed since it is a 32GB but I don't want to pay an arm and a leg.
Score 1
Add a comment
Chosen Solution
This sounds like a broken lcd...
Score 1
Add a comment
The iPad could have sustained a powerful shock. Connect it to the 10watt charging block it came with, and wait to hear for the charging sound(it's okay no to hear it). Wait for at least an hour, then proceed with the following:
#Make sure to disconnect the iPad from the charging outlet
  1. Hold the power button for 30 - 60 seconds
  2. The Apple Logo should appear, if not repeat several times or charge the iPad
  3. After the iPad shuts off release the power button and reconnect it to the charger
  4. wait for 10 - 30 seconds, if the Apple Logo did not appear, hold the power button until it does
If the above did not work, then you should visit a certified technician.
Score 1
Add a comment
Add your answer
ryderkevin will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 58
All Time: 5,980
