Portable Bluetooth Speaker with 14 hour playtime. IPX7 waterproof certified. Shockproof rubber exterior. 1800mAh power bank. Released in 2015.
8 Questions View all
How do I use the speaker without having to connect to Bluetooth?
I do not have bluetooth on my music device and i would like to still play music through the Braven. How would I play music with just an aux cord?
Score 1
Comments:
I want to connect two jacket h2o3 speakers with an auxiliary cable to my tablet can this be done
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
To use the Braven BRV-1s without having to connect to Bluetooth use a standard 3.5mm auxiliary cable to plug your device into the speaker. The auxiliary port is located at the back of the speaker underneath the waterproof cap next to the charging ports.
Note: If you are using the auxiliary port then your device will not be waterproof.
If for some reason the speaker is not producing sound when the auxiliary cable is plugged in please refer to this troubleshooting page to identify the possible problem. ''Braven BRV-1s Troubleshooting''
Score 1
Add a comment
Most Helpful Answer
Hi,
I assume that you would just connect a 3.5mm stereo audio cable (refers to the plug size not the length) between your music device (usually connects to the headphones connection point) and the aux input connection on the Braven and press power to start. The user guide does not mention anything about auxilliary input function except that it has an aulilliary input.
There is this warning in the user guide to be aware of though, unsure whether it affects auxialliary input operation or not.
NOTE: If your BRAVEN does not have an active Bluetooth® connection and is left on, it will shut itself off after 30 minutes to preserve the battery. To restart your BRAVEN you will need to press and hold the power button for 2-3 seconds.
Score 2
Add a comment
Add your answer
Brendan Nocis will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 74
Past 30 Days: 367
All Time: 3,394
