The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3758 Questions View all
Can't hear callers unless I turn on the speakers!
A week ago I changed the battery of my iPhone 5s. Since then, I can't hear callers anymore unless i activate the speaker. This is not very comfortable, especially if I want to make calls on the road. The front camera is also not working anymore since then.
What I already tried: I thought the earpiece speaker is damaged and replaced it, but still the same problem. What else could it be?
Thanks a lot for your help!
Score 1
Add a comment
1 Answer
Good morning!
1 - you checked if you connected all right?
2- If the problem persists, clean well the connection ports .
3 - if anything Previous work for you, you probably are damaged ports on the motherboard and you have to change it!
Comments:
1. Yes, I checked all connections, they are all right connected.
2. I also cleaned the connection ports.
So you think there's a damage on the motherboard? If I'd replace it, I can't use TouchID anymore, alright? Any other possibilities what could be wrong?
by
Add a comment
Add your answer
Christof Wittwer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 89
