Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
3627 Questions View all
iPhone constantly searching for carrier (stuck on searching)
Apple Iphone 6 White att EUA stuck on searching. I already replaced charging port, battery, screen, and still having the problem. I need help :/
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Disconnecting then reconnecting the battery. Then connect to wifi. You could also try a different SIM card. You could also try resetting your carrier settings. You could also try a force restart. You could also try backing up the phone then doing a restore. At least you'll have the backup. By the way the color of the phone doesn't make a difference
iPhone 6 Battery Replacement
How to Force Restart an iPhone 5
iPhone 6 Battery Image
Guide
Difficulty: Moderate15 - 45 minutes
iPhone 5 Image
Guide
Difficulty: Very easy30 seconds
Score 1
Comments:
Ok imedicminneapolis , already did everything , but not works. I have the backup.
by
Add a comment
Check your date and time.
This happens a lot when disconnecting the battery for an extended period of time. Sometimes connecting to a WiFi network will re-sync the time, but if it doesn't you can change it manually. I think they default back to January 1st 1973 or something like that and due to iOS being the OS that it is, changing it forward 42 years (month by month on the dials) isn't quick, but it works
Comments:
phonesurgeon , the date and time is updated. Even when I disconnected to the wifi, and restore or restart the phone, the time and date continue updated.
by
Add a comment
Does your iPhone have an IMEI number? Check to see if it is blacklisted also
Add a comment
Did you find an issue ?
Same thing for me
Thanks
Add a comment
Add your answer
marcoherberty will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 39
All Time: 639
