A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
650 Questions View all
I turned off my display , how do I fix it?
I was trying to set up a projector, and I accidently turned tly turned off my Toshiba satellite c655-s5060 display. Now I can't see what I'm doing to turn it back on. I tried to hook it up to a second moniter, but that didn't work. What can I do without losing all my assignments?
Add a comment
1 Answer
Chosen Solution
Can you start in "safe mode"?
To enter safe mode:
Turn on PC then immediately start pressing F8 (not a continuous press- quickly press press press - if beeping occurs stop for a second or two then start presses again). if you time it right you should get a screen display which gives you the option to Start Windows in various modes Use arrow keys to select "Safe mode" then press enter.
If you don't get this screen turn off PC and try again.
Once Windows loads you will have a desktop display with "safe mode" in the 4 corners
Then go to Start -- Control Panel -- Appearance and Personalization --- Adjust Screen Resolution
This should get you where you want to be to select your display. Once you have changed and saved your settings restart PC
Score 1
Add a comment
Add your answer
Wolframgotts will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 67
