4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
372 Questions View all
Charging port will not charge, Want to only replace port.
I need to replace my charging port, I screwed it up pretty badly. The only problem is that my broken touch screen is in the way. I don't care about the screen that much but if I use the suction cup I think it will shatter and I don't want to replace it for 80$. Can i only replace the glass and keep the LCD? If so how? I am trying to repair on a budget. Any help will be greatly appreciated. Thanks!
Add a comment
1 Answer
Chosen Solution
Luke Johnston, there is no cheap why to go. You will need an LCD separator as well as proper adhesive to fuse the glass/LCD. If you do not have the tools, they will cost you more than 2 new display assemblies. If you have the tools but have never done it, your success rate will be low, You may end up paying twice as much. I suggest to replace the complete assembly. It will be less expensive in the long run and you are almost guaranteed to get it working right the first time.
Score 2
Add a comment
Add your answer
Luke Johnston will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 74
