Repair information for the gear you use to get out and get active.
61 Questions View all
How do I replace the battery in a Nike + sensor?
Please also provide the battery type or model number if you can.
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
Check this guide from instructables, tells you all you need to know.
Add a comment
The battery is a Panasonic 3v BR2032. Transmitter plate black and white wires glued to + side of battery. Battery +Red and -Black wires soldered. Not an easy replacement!
Add a comment
Add your answer
jason will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 6,328
