The Samsung Galaxy Tab 4 8.0 from Verizon (SM-T337V), also known as the Samsung SM-T335, was launched on April 1, 2014. The 8-inch tablet is powered by a 1.2 GHz quad-core processor, has a multi window functionality, and a 3 megapixel camera.
21 Questions View all
Why does my tablet have difficulty connecting to the Wi-Fi?
My Tablet keeps jumping on and off, but not connecting to the Wi-Fi, and my patience is worn out.
Add a comment
Chosen Solution
You have several ways to be out of the woods. Select a network and then re-enter the password or select other Wi-Fi signal to see if it works. Otherwise, try to move your location to see if your tablet can connect to a stonger signal elsewhere. Remember, sometimes a wall or, even buildings, can be your enemies.
Score 3
Add a comment
try to backup your device the wipe it by pressing the home button and the volume button up simultaneously
select factory wipe and reboot the device, try to connect with wifi it should connect then restore your infos
if it does not connect and that you are confident to open the device cheick for wifi cable if it s is connected
Add a comment
Add your answer
Yvonne Lai will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 106
