Repair and disassembly guides for microwave ovens.
416 Questions View all
What makes the microwave sound like it is struggling for power?
You put in a cup of coffee to heat up and it sounds like a train, when its beginning to slowly travel at start up. But it stays that way, continually struggling to build up its power.
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Hi,
Is the turntable rotating smoothly , does it struggle to move? Check for "flat spots" on the "wheels" of the ring shaped roller or Y shaped roller, whatever sort supports the turntable.
If so you can buy a new ring shaped roller or Y shaped roller( whatever is applicable to your particular brand and model microwave), that the turntable rests on. These come with "wheels", as a complete unit. Unfortunately you can't buy the "wheels" separately.
If it is not the "wheels" it may be the turntable drive motor gears slipping. You have to then buy a new drive motor.
Score 1
Add a comment
Add your answer
jker5053 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 143
