Oscillating tower fan with 5 Speeds/Levels of sound control. Equipped with variable time settings and a portable remote control.
5 Questions View all
Why isn't the fan oscillating?
I've had this fan for over a year without any problems. I tried using i today and the fan is no longer turning as it normally does. It still blows air but doesn't move back and forth. Help!
Add a comment
1 Answer
Chosen Solution
If the fan isn't oscillating, check that both the remote and front panel are functional to eliminate the chance that the button is simply broken. If this does not help, remove the back casing from the fan. Then, locate any debris or objects that might have gotten into the fan and blocked the oscillation motor. If the fan is still not oscillating, replace the oscillation motor assembly using this guide.
Score 1
Add a comment
Add your answer
Nicolas Romero will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 64
Past 30 Days: 437
All Time: 3,962
