Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2920 Questions View all
How to install ios in new memory of iPhone?
Hello sir,
I want to upgrade my iPhone storage. So I decided to replace it by myself. I just want to ask you if I replace sd card, how to install ios in that new sd card because it is not activating also ?
Hope you will help me !
Thank you in advance !!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Well, I'm sorry to tell you. There is no sd card for iPhone. They have chips, that are soldered onto the logic board, that dictate how much storage the device has. You can use, and purchase, iCloud storage. However, I've noticed people saying that doesn't help. I don't like using it. With iPhones, bigger memory is better memory
Score 2
Add a comment
You have to desolder the chip, put it on the programmer to load low-level data (unit S/N, MLB S/N, model code and other stuff like that). Then write it into the new chip and solder it back on. It is possible and we already have a few vendors offering this service in China. Not economically viable for iPhone 4s however.
And it is possible that Apple will add more verifications in the update so phones with replaced memory chips might break.
Score 2
Comments:
Sorry, Tom is totally right. It is a possibility. Technically on the outside; as micro soldering is still a new thing. At least in the states. You could hit up Jessa Jones at iPad Rehab. I think she's east coast, and her business is mail in. Also, not sure if error 53 affects i4S. But any tampering with your iDevice, followed by an iOS update, could result in bricking your phone. So, basically, don't update. Apples new stuff is not your friend
by
Add a comment
Add your answer
shubh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 97
