Why won't my camera turn on?
So I was in the middle of using my camera when it shut off on it's own with the lens zoomed out. I looked it up and it seems like a fuse may have blown, can anyone recommend a good repair shop or online repair service? I love this camera and it sucks knowing this has happened : (
Add a comment
1 Answer
Hi,
Panne courante sur cet appareil , vis se desserrant à l'intérieur , court-circuit , fusible de la carte alimentation grillé .
C'est un fusible CMS composant de surface ; il faut être spécialiste pour le changer ; sinon changer la carte alimentation DC/DC , on peut en trouver à 25$ sur le net ,ou recouvrir le fusible de pâte conductrice
( plus aléatoire )
Current breakdown on this unit, screws become loose inside, short circuit, the power board fuse blown.
CMS is a fuse surface component; you have to be a specialist to change it; otherwise change the power board DC / DC, one can find $ 25 on the net, or cover the conductive paste fuse
(More random)
Add a comment
Add your answer
ryokobarton2 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 697
