Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
283 Questions View all
MacBook Pro 13" A1502 (late 2013) will not boot, harddrive removal?
MacBook Pro 13" A1502 (late 2013) will not ot boot do to a full startup file. How do you remove the harddrive to connect a SATA as a means of retrieving data as well as deleting files from the harddrive so when it is placed back in my MacBook Pro it will them start?
Thank you,
William
Comments:
Thank you for your assistance, however the Target Mode would not work. Is there an mSATA USB adapter you would recomend for MacBook+Pro+13-Inch+Retina+Display+Late+2013+SSD or is the mSATA a universal adapter?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
First there is no hard drive, it's a mSATA: MacBook Pro 13" Retina Display Late 2013 SSD Replacement
You can boot it in Target Mode and drag the data off. You can use an external USB drive with a system on to boot from and then drag it off.
Score 1
Comments:
Thank you for your assistance, however the Target Mode would not work. Is there an mSATA USB adapter you would recomend for MacBook+Pro+13-Inch+Retina+Display+Late+2013+SSD or is the mSATA USB adapter universal.
by
Add a comment
Add your answer
William will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 31
All Time: 898
