Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Questions View all
Question Closed
MacBook Pro 13" A1502 (late 2013) will not boot, harddrive removal?
MacBook Pro 13" A1502 (late 2013) will not ot boot do to a full startup file. How do you remove the harddrive to connect a SATA as a means of retrieving data as well as deleting files from the harddrive so when it is placed back in my MacBook Pro it will them start?
Thank you,
William
1 Comment
Thank you for your assistance, however the Target Mode would not work. Is there an mSATA USB adapter you would recomend for MacBook+Pro+13-Inch+Retina+Display+Late+2013+SSD or is the mSATA a universal adapter?
by
Add a comment
1 Answer
Chosen Solution
First there is no hard drive, it's a mSATA: MacBook Pro 13" Retina Display Late 2013 SSD Replacement
You can boot it in Target Mode and drag the data off. You can use an external USB drive with a system on to boot from and then drag it off.
Score 1
2 Comments:
Thank you for your assistance, however the Target Mode would not work. Is there an mSATA USB adapter you would recomend for MacBook+Pro+13-Inch+Retina+Display+Late+2013+SSD or is the mSATA USB adapter universal.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,766
