Keyboard doesn't function correctly.
I have some problems with my keyboard. The volume goes up every time I press the spacebar or some thing pops up unexpectedly on the screen when I type. Does the keyboard have any problem? Or is it a software issue? Can anyone show me how to fix it? And what's the cost gonna be?
4 Comments
Need a bit more here. Did you get your system wet some how? Spill a drink into the keyboard or set the system down on a wet surface?
by Dan
Are you up to fixing this your self? This is not an easy repair as you will likely need to replace the upper case which is were the keyboard is mounted.
by Dan
Where should I get it fixed? I'm located in Dallas, Texas.
by Chris Nguyen
I didn't get any liquid dropped in it.
by Chris Nguyen
